Wie finde ich heraus wo die optimale drehzahl meines HK 4225 610KV LE Motor ist?
<script type="text/javascript"> function prefill(){ var data = document.getElementById('heli').value; var value = data.split("|"); if(data != ""){ if(value[0] >= 1){ document.getElementById('maingear').value = value[0]; } if(value[1] >= 1){ document.getElementById('tailratio').value = value[1]; } if(value[2] >= 1){ document.getElementById('rpv').value = value[2]; } if(value[3] >= 1){ document.getElementById('pinion').value = value[3]; } if(value[4] >= 2){ document.getElementById('cells').value = value[4]; } calculate(); } } function calculate(){ var maingear = document.getElementById('maingear').value; var tailratio = document.getElementById('tailratio').value; var rpv = document.getElementById('rpv').value; var pinion = document.getElementById('pinion').value; var cells = document.getElementById('cells').value; var coeff = document.getElementById('coefficient').value; if(tailratio != ''){ tailratio = tailratio.replace(',','.'); } if(maingear >= 1 && rpv >= 1 && pinion >= 1 && cells >= 2 && coeff >= 70){ var ratio = pinion / maingear; var mspeed = rpv * cells * 3.7; var headspeed = mspeed * ratio * (coeff / 100); var tailspeed = headspeed * tailratio; headspeed = Math.ceil(headspeed); tailspeed = Math.ceil(tailspeed); if(headspeed >= 100 || tailspeed >= 100){ //document.getElementById('header').innerHTML = "Berechnete Drehzahlen"; if(headspeed >= 100){ document.getElementById('headspeed').innerHTML = "<div style=\"display:inline-block; width:60px;\">Kopf</div><div style=\"display:inline-block; width:100px; text-align:right;\">"+headspeed+" U/Min</div>"; } if(tailspeed >= 100){ document.getElementById('tailspeed').innerHTML = "<div style=\"display:inline-block; width:60px;\">Heck</div><div style=\"display:inline-block; width:100px; text-align:right;\">"+tailspeed+" U/Min</div>"; } } else{ document.getElementById('header').innerHTML = "Bitte überprüfen Sie die Eingaben"; document.getElementById('headspeed').innerHTML = " "; document.getElementById('tailspeed').innerHTML = " "; } } } function wipe(){ document.getElementById('header').innerHTML = " "; document.getElementById('headspeed').innerHTML = " "; document.getElementById('tailspeed').innerHTML = " "; document.getElementById('heli').value = ""; document.getElementById('maingear').value = ""; document.getElementById('tailratio').value = ""; document.getElementById('rpv').value = ""; document.getElementById('pinion').value = 7; document.getElementById('cells').value = 2; document.getElementById('coefficient').value = 100; } </script> <div> </div> <img src="[url="http://www.mcw-online.de/bilder/heli.gif"]404 Not Found[/url]" alt="" height="98" width="150" border="0"> <div> </div> <div style="width:400px; margin:0 auto;">Voreinstellungen<p><select name="heli" id="heli" onchange="prefill();"> <optgroup label="Keine Vorgabe"> <option value="">Eigene Daten</option> </optgroup> <optgroup label="Heli Vorgaben"> <optgroup label="Thunder Tiger Raptor E550"> <option value="111|4.56|1050|10">Thunder Tiger OBL 43/11-30H 1050KV</option> <option value="111|4.56|1150|10">Thunder Tiger OBL 44/11-30H 1150KV</option> </optgroup> </select></p></div><table class="hidden_tab" style="width:400px; margin:20px auto;"><tbody><tr><td style="vertical-align:top;" width="160"><span id="header"> </span></td><td width="*"><span style="font-size:13pt;" id="headspeed"> </span><br><span style="font-size:13pt;" id="tailspeed"> </span></td></tr><tr><td colspan="2" width="*"> </td></tr><tr><td width="160">Zellenzahl</td><td width="*"><select name="cells" id="cells" onchange="calculate();"><option value="2">2S (7.4V)</option> <option value="3">3S (11.1V)</option> <option value="4">4S (14.8V)</option> <option value="5">5S (18.5V)</option> <option value="6">6S (22.2V)</option> <option value="7">7S (25.9V)</option> <option value="8">8S (29.6V)</option> <option value="9">9S (33.3V)</option> <option value="10">10S (37V)</option> <option value="11">11S (40.7V)</option> <option value="12">12S (44.4V)</option> <option value="13">13S (48.1V)</option> <option value="14">14S (51.8V)</option> </select></td></tr><tr><td width="160">Hauptzahnrad Zähne</td><td width="*"><input name="maingear" id="maingear" value="" style="width:60px;" onchange="calculate();"></td></tr><tr><td width="160">Heckrotor-Ratio</td><td width="*"><input name="tailratio" id="tailratio" value="" style="width:60px;" onchange="calculate();"></td></tr><tr><td width="160">Motorritzel</td><td width="*"><select name="pinion" id="pinion" onchange="calculate();"><option value="7">7 Zähne</option> <option value="8">8 Zähne</option> <option value="9">9 Zähne</option> <option value="10">10 Zähne</option> <option value="11">11 Zähne</option> <option value="12">12 Zähne</option> <option value="13">13 Zähne</option> <option value="14">14 Zähne</option> <option value="15">15 Zähne</option> <option value="16">16 Zähne</option> <option value="17">17 Zähne</option> <option value="18">18 Zähne</option> <option value="19">19 Zähne</option> <option value="20">20 Zähne</option> <option value="21">21 Zähne</option> <option value="22">22 Zähne</option> <option value="23">23 Zähne</option> <option value="24">24 Zähne</option> <option value="25">25 Zähne</option> <option value="26">26 Zähne</option> <option value="27">27 Zähne</option> <option value="28">28 Zähne</option> <option value="29">29 Zähne</option> <option value="30">30 Zähne</option> </select></td></tr><tr><td width="160">Motor KV (U/V)</td><td width="*"><input name="rpv" id="rpv" value="" style="width:60px;" onchange="calculate();"></td></tr><tr><td width="160">Wirkungsgrad</td><td width="*"><select name="coefficient" id="coefficient" onchange="calculate();"><option value="100" selected="">100%</option> <option value="99">99%</option> <option value="98">98%</option> <option value="97">97%</option> <option value="96">96%</option> <option value="95">95%</option> <option value="94">94%</option> <option value="93">93%</option> <option value="92">92%</option> <option value="91">91%</option> <option value="90">90%</option> <option value="89">89%</option> <option value="88">88%</option> <option value="87">87%</option> <option value="86">86%</option> <option value="85">85%</option> <option value="84">84%</option> <option value="83">83%</option> <option value="82">82%</option> <option value="81">81%</option> <option value="80">80%</option> <option value="79">79%</option> <option value="78">78%</option> <option value="77">77%</option> <option value="76">76%</option> <option value="75">75%</option> <option value="74">74%</option> <option value="73">73%</option> <option value="72">72%</option> <option value="71">71%</option> <option value="70">70%</option> </select></td></tr><tr><td colspan="2" width="*"> </td></tr><tr><td style="text-align:right;" width="160"><button onclick="wipe();" style="margin-right:5px;">Löschen</button></td><td width="*"><button onclick="calculate();">Berechnen</button></td></tr></tbody></table></font>
